Type 9 bellhousing Swap
Old Sep 1, 2015 | 06:55 PM
Jack and the Beanstalk's Avatar
Default Type 9 bellhousing Swap
Hi All
I would like to find out. If I'm running a standard 2.0 L engine with type 9 gearbox with 2.0L bell housing can I use the same gearbox on a V6 engine with the a v6 bell housing or would I have to buy a v6 type 9 gearbox?
Please advise
Old Sep 1, 2015 | 10:18 PM
jon@work's Avatar
jon@work
IIRC, the input shafts are different lengths between the 4 cylinder and V6 type 9 boxes
Old Sep 8, 2015 | 07:09 AM
What about a V6 type 9 gearbox fitted to 3.0 Essex motor.
If I change the bell hosing only to v6 cologne for a 2.9 v6 Cosworth BOB engine would that configuration work for my BOB provided I have the correct diff and prop setup?
On that note could I also use the 3.0 V6 Essex flywheel on a 2.9 V6cologne Cosworth Bob motor?
Please advise
Old Sep 13, 2015 | 06:39 AM
Any recommendations on the above with swapping out Essex bell housing to a Cologne? Gearbox would have been originally been fitted to 3.0 v6 Essex motor.
Old Sep 13, 2015 | 09:32 AM
Mark V8's Avatar
Mark V8
From what I remember you can mix and match bell housings.
Years back my brother fitted a 5 speed type 9 to a 3 litre Capri using a V4 transit bell housing.
As far as I'm aware, over here the type 9 was never fitted to the Essex V6...
If you try and fit an Essex V6 gearbox to a BOB the input shaft might not be long enough as the when fitting a type 9 to the Essex the input shaft needs to be shortened.
Did you not get any 2.8i Granadas or Capris you could get a gearbox from out there ?
Old Sep 13, 2015 | 03:46 PM
Thanks Mark
I'll have to check for maybe a very old one. Mostly the Granada's here, 2.0L, 3.0L v6 and 3.4L
The Cortina as well, very much similar
Will look into Capris but not easily found.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
grishenko45
Sep 9, 2015 12:58 PM
