Air filter replacement Ford Ka
Old Aug 28, 2015 | 11:54 AM
Franko99's Avatar
Franko99
Default Air filter replacement Ford Ka
My wife has a Ford Ka 2005 model and I'm going crazy trying to get at the air filter!! I can see the housing, I've unfastened the two spring clips on the top, disconnected the jubilee clip on the side hose, taken out two screws holding on the plastic air intake to the body at the front. Still cant move it!!
I've looked at Haynes (but it's unintelligible to me).
HELP
Franko99
Old Aug 29, 2015 | 01:38 PM
Franko99's Avatar
Franko99
Default Ford KA 2005 air filter replacement
I think I have an answer now, I'll post it for future reference as it is not obvious how to do it !
REMOVING THE AIR FILTER FORD KA 2005
1)
Pull off pipe from rocker box and release it from u clip at front end of air cleaner box.
2)
Undo hose clip and draw back intake hose. It will detach completely when the air box is withdrawn later
3)
Do not touch the Philips screw but observe the u shaped plastic shoulder which surrounds the ‘beak’ and below it is a joining.
4)
Carefully insert the tip of a very thin bladed screwdriver and carefully lever up this moulding, it will then be obvious how the air box is attached to the front cross beam.
5)
Lift up the assembly and withdraw from the car
NOTE
It is possible to open the box by unfastening the spring clips to observe the air filter but to change it the whole assembly has to be removed first
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
track.focus'd
Aug 12, 2015 05:53 PM
Escortdriver1
Aug 5, 2015 12:45 PM
Escortdriver1
Jul 31, 2015 02:36 PM
