cosworth serious hesitating under accelerating!
Old Aug 27, 2015 | 04:49 PM
wheelwizardrefurbs's Avatar
wheelwizardrefurbs
Default cosworth serious hesitating under accelerating!
Ok i finally got my car running (sierra cosworth L6 ecu stage 1) but it has a horrible hesitation problem under load, it idles perfectly and if i slowly rev its great but if you blip the throttle or floor it it just goes mental, i have changed the following items
Crank sensor
Phase sensor
Dizzy cap & rotor arm
New spark plugs
Timing is ok
all gaps are good
Its driving me insane could anybody help with suggestions! Thanks!
Old Aug 27, 2015 | 04:53 PM
Sierrasideways's Avatar
Sierrasideways
Coil? FPR?
Old Aug 27, 2015 | 04:55 PM
wheelwizardrefurbs
hi mate i will try another coil as i dont know much about the one i fitted also i fitted an adjustable fpr set to 3 bar. cheers
Old Aug 27, 2015 | 04:58 PM
Sierrasideways
Best o' luck. Keep us posted
Old Aug 27, 2015 | 05:02 PM
wheelwizardrefurbs
thanks mate i need it lol
Old Aug 27, 2015 | 07:56 PM
jamie's's Avatar
jamie's
How did you set the fuel pressure reg?
Was the 3 bar set with the vacuum on or off?
Is it definately a rising rate type regulator?
Check voltage at fuel pump as well
Old Aug 27, 2015 | 08:23 PM
wheelwizardrefurbs
hi mate the regulator is just an ebay cheapy jod 3 bar was set with the vacuum off cheers
Old Aug 28, 2015 | 08:06 PM
wheelwizardrefurbs
just a quick update the spark plugs are thick with black soot (DRY) it also pops and bangs when revvved hard. cheers
Old Aug 28, 2015 | 10:12 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Cheapy fuel pressure regulator
Old Aug 29, 2015 | 06:37 AM
wheelwizardrefurbs
so i take it you think a genuine reg will sort my problem out?
Old Aug 29, 2015 | 06:05 PM
wheelwizardrefurbs
??? mad mat
Old Aug 29, 2015 | 07:46 PM
1300gt's Avatar
1300gt
Check your alternator output voltage is good and consistent... Fuel pump and loom/conections. How is your ECU loon conections and harness
Old Aug 29, 2015 | 08:57 PM
mjonathan24's Avatar
mjonathan24
if its not been run for a while it may need a bit of a setup
Old Aug 30, 2015 | 12:26 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
I have no idea if it will sort it. My point is fuel pressure is critical on these Turbo motors and you have a cheap n cheerful regulator fitted. Cheap is fine as long as it works bang on.
I thought fuel pressure should be 3.5bar with vac hose disconnected? Dropping to roughly 3bar at idle with hose connected.
Can someone else confirm please before this chap melts a piston.
Old Aug 30, 2015 | 07:57 AM
wheelwizardrefurbs
Hi mate sorry thats what i meant i set it to 3.5 bar with vac off and it drops to 3 bar with vac connected, my alternator is brand new 65 amp would that cause such erratic behaviour? fuel pump is brand new 044, connections all seem fine mate, i may change the regulator for a standard one if i can find one.. thanks for the replies.
Old Sep 2, 2015 | 07:45 PM
gcfcos's Avatar
gcfcos
I'm sure Alternator should be 90amp on a Cossie. Mine is and so are a couple of mates ones that I've replaced alternators on.
Old Sep 3, 2015 | 04:42 PM
wheelwizardrefurbs
hi mate yes ive checked and apparently there is a 70 and a 90 amp. but do you really think this would make a massive difference? cheers.
Old Sep 3, 2015 | 05:26 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
70 amp is for non heated screen models 90 amp is for heated screen models
You can use either on the non heated screen models
Old Sep 5, 2015 | 05:37 PM
RobertM's Avatar
RobertM
Check your MAP sensor, i had the same problem.
Luckily I have a monitor so I saw right away that my MAP pressure
shouldn't be 1 bar with engine turned off.
Old Sep 5, 2015 | 09:15 PM
wheelwizardrefurbs
thanks for the replies guys, i am deffinatley going to try the map sensor as its popped up a lot in conversations with others. i dont have a heated screen mate so hopefully it should be ok. cheers again
Old Sep 23, 2015 | 09:14 PM
wheelwizardrefurbs
SORTED!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
