2000 focus zetec usb light ?
Old Aug 20, 2015 | 01:51 PM
jaysoc1's Avatar
jaysoc1
Default 2000 focus zetec usb light ?
hi all I got my wife a 2000 plate focus zetec the car is looking pretty ruff
but it is only for hur work
I was wondering if anyone has any advice on the two usb conections that sit where the cig lighter would go , as my wife would like to charge hur phone when using the car I put a fuse in ( as there wasn't one in ) and it is all working fine the only problem is the blue light that comes on since putting the fuse in wont go out even when the car is off and locked and im worried about this draning the battery as I don't want hur getting stranded at work
many thanks
Jamie
Old Aug 20, 2015 | 02:02 PM
Caddyshack's Avatar
Caddyshack
I bet that is why they removed the fuse. I would probably not worry about the tiny drain that a little light puts on.
I suspect someone has changed the wiring from switched live (needs the ignition on) to perm live (still charge phones with key off) so either wire it to a switched live or try and work out if the LED is on its own part of the circuit within the USB, you could just cut the feed to the usb as long as the LED is not used to drop the voltage from 12v to 5V that USB work off. It is easy to find a switched live but getting a simple tester or light bulb, one end on earth and other prod around to find a live and then when live found turn off key and see if it goes out...to be safe chuck another in line fuse in...if in any doubt.
I hope this helps?
Old Aug 20, 2015 | 02:23 PM
jaysoc1's Avatar
jaysoc1
thanks caddyshack
your prob rite about the reason there was no fuse in there lol
I will try having a look at it and fine out if I can sort it as the wife is
hopeing she can use the usb
Old Aug 20, 2015 | 02:47 PM
jaysoc1's Avatar
jaysoc1
Unhappy
anyone know how to get the cig lighter out
it is located up near the steering wheel and
looks like it will be a pain to get out
Old Aug 20, 2015 | 02:59 PM
Caddyshack's Avatar
Caddyshack
Are you able to post a pic? I have only ever sat in a focus once before. I suspect you may need to remove the whole panel and get at it from behind....I often start removing stuff around the panel and all becomes clear....just don't force anything. Once you find the first bit to come off it normally reveals the next step in the process. I bet you could google it and see a you tube how to
Old Aug 20, 2015 | 03:02 PM
Caddyshack's Avatar
Caddyshack
Looks like stereo out first.
Old Aug 20, 2015 | 04:22 PM
STeve's Avatar
Super Moderator
Biggest problem you have is the socket is permanent 12v, loads of these cheapo usb sockets are bloody dangerous and cant handle phone charging or sat nav loads for periods of time, if you buy the stubby little adaptors like a belkin they have a good safety rating and once fitted they virtually go flat with the facia so dont look naff, and easily removed
Old Aug 20, 2015 | 04:25 PM
Caddyshack's Avatar
Caddyshack
I did wonder if a car from 2000 would have had it as factory fit back then
Old Aug 20, 2015 | 06:06 PM
jaysoc1's Avatar
jaysoc1
It looks like a factory fit , if it was my car I'd just leave the fuse in and see if it drains the battery but as its my wife's car I'd better not , I've taken the fuse out for now tho I would like to try and fix the problem for hur , I've tried to look up the problem online but I'm struggling to find any info about it
Old Aug 20, 2015 | 06:20 PM
STeve's Avatar
Super Moderator
its not OE its ebay 100%, and that one was the type I was refering too of being dangerous as they cant handle the loads quoted
Old Aug 20, 2015 | 06:25 PM
jaysoc1's Avatar
jaysoc1
Ah ok I'd prob just be best to leave the fuse out , or buy a better brand one and try to replace it just don't think my wiring skills would be up to it .
Old Aug 20, 2015 | 06:30 PM
STeve's Avatar
Super Moderator
found a advert with the exact same one in it as yours
http://www.ebay.co.uk/itm/like/12V-D..._qi=RTM2063738
you are far better off fitting the original socket back in and using one of these types as you can remove it or the usb type from a tom tom as its well filtered
http://www.ebay.co.uk/itm/GENUINE-BE...item3aaff128ba
Old Aug 20, 2015 | 06:40 PM
jaysoc1's Avatar
jaysoc1
Thanks for the advice , I wonder how much work would be involved in fitting a cigarette lighter back in there tho , as I'm not the best at the whole wiring thing tho it would be better as my sat nav is not usb it the cig lighter charger type
Old Aug 20, 2015 | 06:42 PM
STeve's Avatar
Super Moderator
it is a easy job, once stereo is out undo 4 screws on facia and it will pull out enough for you to swap them over as wiring should be plug and play unless whoever fitted that socket bodged it in
Old Aug 20, 2015 | 07:01 PM
Caddyshack's Avatar
Caddyshack
Yup, doddle to do, I bet halfords would even do it for you, if not then a decent stereo shop.
Old Aug 20, 2015 | 08:18 PM
jaysoc1's Avatar
jaysoc1
Thanks lads I took the stereo out and managed To fit my hand inn to screw it out and it is just two plugs at the back so it will be a trip to halfords tomorrow for a new cig lighter and I've ordered a new charger from eBay 😀 thanks for all the help , my wife is now off my case well for now till the next thing crops up lol
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
robnock
Aug 22, 2015 10:51 AM
jaysoc1
Aug 21, 2015 05:38 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
