Xr3i efi (non-uk) -> Ofac/ofab wiring
Old Aug 19, 2015 | 07:06 PM
Dahl88's Avatar
Dahl88
Default Xr3i efi (non-uk) -> Ofac/ofab wiring
Hi guys.
Reedited this thread.
Will a ofac/ofab loom fit directly in my old xr3i mk4 ? Im already running the 3i efi loom, its a eu spec tho, making it with a lambda.
Since nobody knows if the ecus are the same (some believe the lambda takes up the co-pot pin) im starting over fresh.
Will my rec counter work, with ofac or ofab? Or do i need to make changes in the loom?
Cheers.
Old Aug 22, 2015 | 08:16 PM
EoinXR3's Avatar
EoinXR3
I think your questions will be answered if you read the sticky
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
