S2 rs turbo lost spark
Old Jul 31, 2015 | 11:17 PM
adriansaleem's Avatar
adriansaleem
Default S2 rs turbo lost spark
My escort rs turbo series 2 has no spark at the spark plugs. The distributor, air mass meter and ignition coil are all ok. What could it be?
I've tried the light bulb test and there is definitely power in the lt wires.
Old Aug 1, 2015 | 06:24 AM
london_chris's Avatar
london_chris
How are you testing your coil? Tried replacing the rotor arm? Distributor cap?
Old Aug 1, 2015 | 06:18 PM
s1cosse's Avatar
s1cosse
Check the fuse labeled heated seat.
Old Aug 1, 2015 | 09:28 PM
martysmartie's Avatar
martysmartie
Firstly, is there spark at the king lead?
Without knowing that it's impossible to advise.
If not then it's possible the green wire from the ignition module has a break, or it is faulty.
Martin
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
Escortdriver1
Aug 19, 2015 09:02 PM
IAN RS2k
Aug 18, 2015 07:51 PM
