Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk 4 Cooling Fan Not Working
Old Jul 25, 2015 | 09:26 PM
Count on Me's Avatar
Count on Me
Default Mk 4 Cooling Fan Not Working
Are their any electricity geniuses on here?
The radiator fan on my mk 4 1.3 does not work and I have tried all the usual stuff to fix it. The fan works if I wire up a battery to it, so it is not getting power from the ECU. What I have found is that the wiring at the plug to the coolant temperature sensor is only showing 4.5 volts on the meter, and I'm guessing that it should read 12.5 volts? My question is: where do I try and look for the voltage drop? It is impossible to trace the wires anywhere.
Thanks!
Old Aug 10, 2015 | 06:16 AM
Count on Me
Anyone?
markk
Dec 2, 2021 06:59 PM
hydro st170
Ford Focus ST
Aug 28, 2015 01:26 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Zoggon
Aug 10, 2015 10:39 AM
