Polyurethane Steering coupler for 2wd Sapphire.
Anyone else used the Blue polyurethane steering coupler on their Sapphire Cosworth ? My old 1990 original Ford rubber one split apart so the steering was really bad. I have just had the new poly kit fitted and what a difference ! The steering has never felt as good, no play in the wheel at all and steering wheel movement to front wheels moving is exactly the same, like a go-kart!! Well chuffed with it.
One of the best improvements I have had done and would highly recommend it to anyone whose steering feels like its got more play than it should have.
Richard at Tremona Garage fitted it , the only thing he said was he had to fit a couple of washers that the kit didnt have. Took about an hour to fit.
ive mine apart now just looking at the picture on eBay I can't see how it go's together with only 4 nuts. Would be good to see a pic
That's a landrover set up isn't it. Looks the same as a normal Sierra one same rubber type bush. The polly one on eBay has a polly bush two studs and two bolts. 4 nuts and two spacers. Just hard to figure out how it go's together from the pic as the two studs only look threaded on one end?
02380775829. Say that he has just fitted one for Richard Green .
Was under the cossie earlier on and I noticed something abit alarming. I could see that mines already has that polybush installed already so just me being me I gripped the steering Column and gave it a wriggle and there is a lot of up and down movement, about 3-4mm up and down. The column that goes through the bulk head is the part that has lots of play.
I noticed under hard braking my steering wheel shudders like fuck, car has a rebuilt rack, new poly tca's and new track rods so the dodgy movement in my steering is got to be this play I noticed.
Anyone else spotted this and what needs replaced?
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
