Turbo removal
Old Jul 13, 2015 | 05:44 PM
johnboy73's Avatar
johnboy73
Default Turbo removal
hello all,can you remove the turbo and manifold off the engine as one piece without removing the radiator?im removing it as one and then unbolting the turbo so I don't round or snap any bolts/knuckles!
Old Jul 13, 2015 | 06:18 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
Yes, both from above or below... but from above you will most likely scratch your paintwork, from below you'll need to remove the starter.
Old Jul 13, 2015 | 07:05 PM
johnboy73's Avatar
johnboy73
Thanks Karl once again!!!!
Old Jul 15, 2015 | 09:17 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
remove oil return pipe, large rad hose off bottom and headertank.
wing cover over front panel and a car mat between the rad and turbo so you dont hit actuator bracket onto rad.
no scratches and much easier than any other rought out.
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 29, 2015 08:16 PM
kevin36
Aug 14, 2015 08:36 AM
