Abs pump
Old Jul 10, 2015 | 04:33 PM
dal3door's Avatar
dal3door
Default Abs pump
Hello
Need a bit of help does any one no of any company that could recon my
Abs pump/ master cylinder for my 3 door Cosworth it has been sitting around for a few years now and just wanted to get it check over
Thanks
Darren
Old Jul 10, 2015 | 05:45 PM
mpilk's Avatar
mpilk
i have just had the same problem trying to find someone i did not find any one i contacted the manufactor and they could not help i put one of a 4x4 you have to alter the the brake pipes on the bulkhead, i got mine of Gary at rs classics
Old Jul 11, 2015 | 09:37 AM
dal3door's Avatar
dal3door
Thanks I will look in to that
Darren
Old Jul 11, 2015 | 07:20 PM
Caddyshack's Avatar
Caddyshack
I have a 4x4 one if you need it.
Old Jul 12, 2015 | 11:14 AM
Paul_RS's Avatar
Paul_RS
You can dismantle them quite easily (take the motor off the pump) to check if they are free. Biggest problem you'll have if it's been sitting dry for ages is getting the air out of the bugger
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
