coilover clunking
I have just fitted some gaz golds to the sierra , backs went on fine apart from I had to bash the inner wing but the fronts are clunking as the springs is moving when I turn the steering wheel left to right.
any one else have this problem ??
I put the bearing on top of the spring cup , then the nut then the bottom half off the strut top then fitted it onto the car then the strut top then new bolt that came with the gaz coilovers
Have you got the spacer washer that's fits at the top, is stops the bearing being over tightened!! (Somehow, sorry forgot the order it was in).
I think I had this missing initially.
