4x4 pf09 tps setting up help
Old Jun 22, 2015 | 09:13 AM
Marc D's Avatar
Marc D
Default 4x4 pf09 tps setting up help
Hi after some help, had an issue with my old wiring loom which had rubbed through somewhere and was giving my tps a reading off 11.4 volts. Changed the loom for a good used one and having trouble setting the tps voltages up. With the wiring disconnected it reads 4.5volts and if I connect the tps up it reads the same unless I loosen the screws holding it on to the throttle body then it goes to 0volts and will smoothly go upto 4.5v as I increase throttle. I've tried another spare pf09 sensor and it does exactly the same. I can't tighten the screws on the tps all the way as it jumps straight to 4.5volts. I tried running the car with the tps reading 0volts and it was idling at 1200 when warm. I'm pretty sure I've read the pf09 shouldn't read 0volts at idle and should be around 0.5volts. I've tried turning the tps to get it reading 0.5 volts but it won't go above 0. Can't figure out what's going on
Any help appreciated
Old Jul 1, 2015 | 10:43 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
what loom have you swapped it with as the wiring positions change when using a pf09 on a 2wd loom.
could be possible that the wiring needs swapping over to be able to get .5v at closed throttle.
like you say it will give an error to the ecu thinking it has no sensor plugged in at idle.
Old Jul 2, 2015 | 03:44 AM
2wd's Avatar
2wd
I adjusted my PF09 to approx 0,23 volts and its spot on. I found the info in an old thread here on PF
Old Jul 2, 2015 | 04:38 PM
Marc D's Avatar
Marc D
I've sorted it now guys. Turns out both my sensors were dodgy, bought another pf09 from Gary at rs classics plugged it in and straight away came up 0.4 volts. Progresses nicely up to 4.8volts as well
Cheers anyway
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
Cragrat
Sep 2, 2015 08:25 PM
