Rs turbo gaskets
Old Jun 21, 2015 | 09:51 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default Rs turbo gaskets
I need a EFI throttle body gasket, where can I get one from?
Old Jun 21, 2015 | 12:48 PM
RSmark84's Avatar
RSmark84
I see you've been a forum user since Dec 2007, So therefore im 99% sure you've tried getting one from Burton Power. If so I can assume you've also tried eBay and Ford directly?
Old Jun 21, 2015 | 05:16 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Waiting on ford bud, need it for my cosworth management conversion
Old Jun 21, 2015 | 05:24 PM
Chopshop85's Avatar
Chopshop85
Are they not just a paper gasket?
Old Jun 21, 2015 | 05:33 PM
Dubs44's Avatar
Dubs44
yes they are mate, i couldn't find a gasket for mine so just bought some good quality gasket paper and made my own and it does the job fine
Old Jun 21, 2015 | 07:15 PM
simonmcf's Avatar
simonmcf
Ford will do it. If you want to ebay it I'd recommend gaskets for classics
Old Jun 21, 2015 | 07:32 PM
studabear's Avatar
studabear
If you are fitting cossie management are you not using a cossie throttle body?
Old Jun 21, 2015 | 09:07 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Good point so just use a Cossie throttle body gasket?
Old Jun 21, 2015 | 09:14 PM
studabear's Avatar
studabear
Yes exactly that, I presume your inlet has been modded to suit the cossie t/b?
plenty of cossie t/b gaskets on ebay.
Old Jun 21, 2015 | 09:36 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Tbh with us I thought the inlet and throttle Body was a fiesta, I got the kit with the inlet and t/b built up. I'll get a Cossie one then.
RSBryden
Sep 6, 2015 08:39 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
