Smoking/oil loss
Ive been having an intermitent rattle/knock/pinking sound, seems to happen when warm and on light throttle.
I noticed today that when it happens and i come off the throttle there was a puff of blue smoke, pretty large to be fair.
Im worried it could be the rings?
Its a 1.6 focus 2003 114k miles.
Update -
Did a compression test today and the results where -
1 - 158psi
2 - 151psi
3 - 121psi
4 - 178psi
Seems a bit all over the place but seems No. 3 is the issue. I just now need to try and find out if it's top or bottom end where the problems Lies...
1 - 158psi
2 - 151psi
3 - 121psi
4 - 178psi
Well believe it or not i (sceptically) ran an engine flush through on the weekend and re-checked the compression it now reads -
1 - 180
2 - 175
3 - 181
4 - 173
Weird but if its worked im happy!
The only issue i still have is that there is a very loud clattering noise when im at between 1500 - 2000 rpm on light throttle, its driving me insane and i dont know what to do, i would really appreiate the help
Thank you for your replys so far
1 - 180
2 - 175
3 - 181
4 - 173
Had the smoke appear again yesterday, always seems to do it while I'm going down hill.
I wasn't touching the throttle at all and as soon as I do I get a cloud of smoke behind me.....any ideas before I go down the replacement engine route?
blakey100
Aug 4, 2015 08:17 PM
