Shudder when braking
Old Jun 14, 2015 | 07:54 PM
jc1989rs's Avatar
jc1989rs
Default Shudder when braking
Hey all
So I'm getting a slight judder through the steering wheel when lightly braking. I thought it was the discs but I've changed them and still the same. Any ideas?
Cheers JC
Old Jun 14, 2015 | 08:01 PM
Mark V8's Avatar
Mark V8
The front hubs can warp - meaning that even new discs can wobble
That being said I had a brand new pair of discs that were badly machined and vibrated like crazy!
Old Jun 14, 2015 | 08:12 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's not discs and not wheels then it could be bushes but ultimatly if it's hubs you need to get them out and machined flat in the first and then, if you can find some, replaced with new
Old Jun 14, 2015 | 08:32 PM
james kiely's Avatar
james kiely
sticky caliper maybe?
Old Jun 14, 2015 | 09:23 PM
jc1989rs's Avatar
jc1989rs
Cheers guys will take the hubs and discs of and put them on my lathe and see if that helps. Will check the bushes to.
Old Jun 25, 2015 | 03:58 PM
HmmDK's Avatar
HmmDK
10 Year Member
dealth with my brake shakes like this:
1. new discs
didnt work...
2. cleaned hubs and put on original steels
didnt work... but helped alot.
3. cleaned hubs very very good, cleaned mounting surface of original steels very good, got new discs (again) and pads, got new front tca`s with all new bushes...
no shakes for 30 days so far !
Old Jun 25, 2015 | 04:57 PM
Marc sierra's Avatar
Marc sierra
In my opinion it will be the outer tca bushes if those are not poly bushes.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
