dip stick popping out
Old Jun 14, 2015 | 03:29 PM
mgtkr1's Avatar
mgtkr1
Default dip stick popping out
I have noticed recently after a hard drive my dipstick pops out. I only noticed by chance as it doesn't affect the idle. the breather is a spec r vented to atmosphere and the car runs about 14 psi. the dipstick does pull out the tube with minimal effort by hand. am I been overly optimistic when I think its just a worn/loose dipstick or could it be a sealing ring that's failed? the motor only has a couple of thousand miles on it sine been built
Old Jun 14, 2015 | 03:52 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Is your rocker cover cap quite a tight fit as I had this yrs ago and it was excessive crank pressure but mine was the cap blowing off, does the engine note change on idle if you pull out the dipstick?
Old Jun 14, 2015 | 04:16 PM
dojj's Avatar
dojj
Resident Wrestling Legend
It's popping out due to crank case pressure
This could be as simple as a blocked breather or as serious as the block being worn and it being blow by
Old Jun 14, 2015 | 05:01 PM
mgtkr1's Avatar
mgtkr1
the cap is one of those crappy aftermarket ones with a grub screw holding it in place which is why it hasn't popped off there. ill try clean the breathers ect. the engine note doesn't even change let alone stall when the dip stick is pulled
Old Jun 14, 2015 | 06:05 PM
dojj's Avatar
dojj
in which case it'll more than likely be a simple blocked breather
think they had an actual filter for the breathers in some of them which might need cleaning out
but i might be on about the fiesta
Old Jun 14, 2015 | 06:06 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
It won't change or stall as you are breathing to atmosphere so will have the metering unit return blocked I'm guessing?
But yes as Dojj has said, check your hoses are not blocked mate.
Old Jun 14, 2015 | 06:13 PM
mgtkr1's Avatar
mgtkr1
thanks karl. yes the metering end is blanked. I never thought about that doh!!! ill give the pipes/breather a good clean, fingers crossed
Old Jun 15, 2015 | 09:37 PM
mgtkr1's Avatar
mgtkr1
just a quick update/ I gave the breather and hoses and flush through yesterday and went out, gave it a big of a kicking and the dipstick is still in place. do they have a habit of getting shitted up in that baffled bit of the rocker cover aswell? I may try giving that a good clean for good measure.
Old Jun 15, 2015 | 10:02 PM
dojj's Avatar
dojj
Not sure you can get a replacement metal filter so just give it a decent clean in petrol overnight
Old Jun 15, 2015 | 11:54 PM
mgtkr1's Avatar
mgtkr1
cheers dojj
boeb
Jan 9, 2020 05:11 AM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
