Escort cosworth boost clocks wiring
Can anybody help i have a mk5 escort cabriolet and are trying to fit escort cosworth clocks in it as it has a turbo engine so i thought it would look better.
I have managed to locate all genuine clocks and multi plugs just having troble with what wires are lives earth sender wires etc.
on oil pressoure sender there is two outlets one has a G on it the other has WK does anybody know what these mean on back of boost clocks i have six wires.
1. Red
2. Brown
3. Brown/Red stripe
4. Grey/yellow stripe
5. Black/yellow stripe
6. Brown
It would be much appreciated if someone can enlighten me as to what these wires are i have some idea of a couple of them but am getting stuck and dont want to damage anything as these bits are very expensive.
If possible a wiring diagram would be greatfully received.
Thank you in advance.
1. Red
2. Brown
3. Brown/Red stripe
6. Brown
not sure but won't the hose just plug in the back of the boost gauge.
With the lights, they will not just wire up.
the dials are electroluminisent,that means they are not bulbs
they wire up to a black box that powers them up iirc.
As to the oil pressure,the sender bit screws onto the block and the wires wire up to this.
Dave.
Dave.
Escortdriver1
Jul 31, 2015 02:36 PM
