Non Ford parts & other stuff for sale If its not for a Ford, or even not car part... this is the room to sell it!! Starting a topic requires you to have purchased a gold membership.
Brembo Aluminium brake calipers..
Old Jun 10, 2015 | 12:48 PM
VEEDUBBED's Avatar
VEEDUBBED
Default Brembo Aluminium brake calipers..
Right guys,
1 set of large Brembo stoppers with good pads, mounting bolts pins etc £130 posted.
1 set of Brembo Fiat coupè/rs focus Brembos, as above, complete. £140 posted.
Attached Thumbnails Brembo Aluminium brake calipers..-dscn0898-1-.jpg   Brembo Aluminium brake calipers..-dscn0899-1-.jpg   Brembo Aluminium brake calipers..-dscn0902-1-.jpg   Brembo Aluminium brake calipers..-dscn0904-1-.jpg   Brembo Aluminium brake calipers..-dscn0909-1-.jpg
Old Jun 10, 2015 | 05:53 PM
griffo69's Avatar
griffo69
Do you know what mods would be needed to bolt the focus brembos to rs turbo hubs ?
Old Jun 11, 2015 | 04:37 AM
VEEDUBBED's Avatar
VEEDUBBED
You'd def. need a set of metal adaptors, I'm not familiar with the rs turbo so i can't say what measurements would be required, maybe someone else has done this mod and could give more info.
The distance between the two mounting holes of the smaller Brembos is 13cm.
More than likely there are adaptors available on eBay.
Let me know if you need them mate.
Cheers.
Old Sep 8, 2015 | 02:05 PM
R4N SS's Avatar
R4N SS
where are you located?
Will these be a straight fit (once you have the correct brackets) for a 2wd cossie?
I have a set on the saf but want a set for the 3dr. Will be using Focus RS discs
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
