saff cooling fan loom + relay
Hi guys,my cooling fans stoped cuting in,cut a long story short i found the relay to be corroded as it sits outside down at radiator due to previous owner making new loom. Are the looms matt lewis sell easy to fit as i might get new 1. Or has anyone got a relay i could buy?
Very simple to fit mate and does away with all oe wiring, i've just fitted one and put my new fuse/relay on bulkhead panel next to battery, bought mine from MSD but a few companies do sell them, supplied with full fitting instructions any way, I also fitted a grpa coil and braided loom at same time.
Dead simple, it'll take you longer to route the cables than to fit.
Hook up to the battery + - and then plug in to your fan. Red bare wire is for ign live or you can hook it up to + to run when engine off
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
muz
Sep 30, 2015 08:29 AM
