Ingnition ecu wires help
Old Jun 9, 2015 | 10:11 AM
Marino's Avatar
Marino
Default Ingnition ecu wires help
hello everyone,
Yesterday I was looking at the wiring diagram of my erst2 and I noticed that from the ignition ecu starts two wire that are called: KNOCK THRESHOLD ADJUSTMENT and LOW OCTANE ADJUSTMENT (pin 11 and 23)
for curiosity I went to see on the loom of the car and I saw that these two wires are cut.
does anyone know if this is normal or must be connected to something?
Old Jun 9, 2015 | 02:20 PM
Marino's Avatar
Marino
anyone
Old Jun 9, 2015 | 10:36 PM
StephenC's Avatar
StephenC
..BS Motorsport..
Far as I know not normally connected.
Old Jun 11, 2015 | 06:24 AM
Marino's Avatar
Marino
thank you mate
Old Jun 11, 2015 | 06:28 AM
Marino's Avatar
Marino
Default replace knock sensor
Goodmorning
recently my knock sensor does not work more properly . unfortunately I can not find it , does anyone know if you can put something to simulate the sensor , for example a resistance ???
Old Jun 11, 2015 | 09:09 AM
studabear's Avatar
studabear
Could you use a early model ecu which I believe didn't use a knock sensor?
Old Jun 11, 2015 | 10:34 AM
Marino's Avatar
Marino
I had thought about it but I don't have the second ect sensor and I don't know if the first ECU need this
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
griffo69
Oct 4, 2015 11:58 AM
IainRS1700T
Sep 25, 2015 06:44 AM
