Cosworth 36-1 Pulley
Old Jun 2, 2015 | 08:42 PM
McCloud 85's Avatar
McCloud 85
Default Cosworth 36-1 Pulley
Just wanted to know what people use when changing to aftermarket management, is a change to the crank pulley the norm and in which case will one of the types on ebay be good enough? Or is it better to fit just the simple (and much cheaper) toothed wheel to the back of the existing pulley if I can?
Alternatively is there other ways that have proven to be better?
Will be using Omex if that makes any difference.
Thanks
Dan
Old Jun 2, 2015 | 11:10 PM
markk's Avatar
markk
It turned my down and tig'd a 36-1 trigger wheel.
Old Jun 3, 2015 | 09:35 AM
stevieturbo's Avatar
stevieturbo
C**t
Thanks
Dan
If you can fit an OEM wheel, it will always be easiest as it requires no effort.
Or yes you could just install the new trigger wheel onto an existing pulley, and create a bracket for the sensor for this new wheel if required.
Either way both are simple.
Old Jun 4, 2015 | 08:19 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have one im willing to sell.
Steve
jonfoc
16
Sep 11, 2018 05:35 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
dombanks
Sep 21, 2015 08:38 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
