fwd drag
Old Jun 2, 2015 | 07:48 AM
crazycage's Avatar
crazycage
Default fwd drag
couple of pics of my little drag toy
Old Jun 2, 2015 | 08:29 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Wicked! What sort of times are you chasing?
Old Jun 2, 2015 | 08:32 AM
crazycage's Avatar
crazycage
Anything starting with a 10
Old Jun 2, 2015 | 11:35 AM
slammedorion's Avatar
slammedorion
Nice to see one of your cars...
Looks well
Old Jun 2, 2015 | 11:44 AM
lee2cossies's Avatar
lee2cossies
Awesome sleeper! Seen it at the weekend certainly shifts a bit, what power is it?
Old Jun 2, 2015 | 12:13 PM
crazycage's Avatar
crazycage
Clutch was slipping on the rollers last week so couldn't map it properly or get a power figure but I'd say about 350 going by the terminals
Old Jun 2, 2015 | 05:46 PM
Thats mad. Good time for a fwd car.
What's the reason for the back end of the car being up in the air.
Old Jun 2, 2015 | 05:53 PM
crazycage's Avatar
crazycage
To put as much weight as possible over the drive wheels
Old Jun 2, 2015 | 06:36 PM
Dave-Rs's Avatar
Dave-Rs
nice time! what turbo is that?
Old Jun 2, 2015 | 06:57 PM
nevsrevs's Avatar
nevsrevs
Looking good gary. Well done
Old Jun 2, 2015 | 07:09 PM
crazycage's Avatar
crazycage
Borgwarner efr 7064
Old Jun 2, 2015 | 07:23 PM
crazycage's Avatar
crazycage
few other pics
Old Jun 2, 2015 | 07:34 PM
clairendave's Avatar
clairendave
Dave not Claire.
Gary, unless you have already addressed it, keep an eye on the chassis leg, inner wing seems ect. I ended up with a scrap shell as it was pulling it apart. (i had a lot less power too)
Old Jun 2, 2015 | 07:54 PM
crazycage's Avatar
crazycage
Originally Posted by clairendave
Gary, unless you have already addressed it, keep an eye on the leg, inner wing seems ect. I ended up with a scrap shell as it was pulling it apart. (i had a lot less power too)
the car is coming apart over the winter for a roll cage and other chassis work so will be addressed then mate
Old Jun 2, 2015 | 08:17 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Only just seen the exhaust! Bet that sings.
Old Jun 2, 2015 | 08:27 PM
smiley's Avatar
smiley
Love it
Old Jun 3, 2015 | 02:03 PM
gjh's Avatar
gjh
That looks awesome!
Old Jun 3, 2015 | 08:48 PM
turbotrev's Avatar
turbotrev
Nice times mate!
Out of interest is the car road legal at all or is it used solely for the strip?
Cheers Paul
Old Jun 3, 2015 | 09:31 PM
crazycage's Avatar
crazycage
Originally Posted by turbotrev
Nice times mate!
Cheers Paul
Strip only , would make a terrible road car
Old Jun 4, 2015 | 01:38 PM
Scott_Rst's Avatar
Scott_Rst
Such an impressive build! put together quickly, to a high standard, and no doubt will be in the 10's soon! good work!
Old Jun 4, 2015 | 02:00 PM
Cool matey. Does it work then having the weight over the front wheels. I take it this gives the carore traction.
Old Jun 4, 2015 | 07:26 PM
crazycage's Avatar
crazycage
That's the theory mate couldn't say if it's making any real difference or not
Old Jun 5, 2015 | 07:58 AM
What power is the engine producing.
Old Jun 5, 2015 | 08:32 AM
clairendave
Dave not Claire.
It does work, K-Tec racing were turning upto santa pod about 16 years ago, removing the rear shocks and replacing them with a bit of box section whilst the rear end was not under compression.
Old Jun 6, 2015 | 10:37 AM
crazycage's Avatar
crazycage
At the pod now , best so far 11.7@123 with a strong as hell head wind
Old Jun 6, 2015 | 12:03 PM
Fullflush's Avatar
Fullflush
Try the car without jacking the rear, I'm sure it make no difference. Look how many of the serious FWD cars have it.....
Old Jun 6, 2015 | 02:51 PM
crazycage's Avatar
crazycage
I no it makes no difference mate I have a n/a mk2 fiesta that's not jacked and it does the same 60fts .the only reason this is jacked is I put a old set of escort front springs in the rear to make it stiff but there 2" longer
Old Jun 6, 2015 | 04:32 PM
Good going that matey. Can you get decent traction then.
Old Jun 6, 2015 | 05:17 PM
crazycage's Avatar
crazycage
Not really mate 60fts are poor only 1.9 this time out .I've done 1.8s before but should be doing 1.6s or better lots to do lol
Old Jun 6, 2015 | 06:48 PM
Fullflush's Avatar
Fullflush
Will you be at pod tomorrow? I'll look out for you if so
Old Jun 6, 2015 | 06:59 PM
So the hardest part is getting the car off the line then.
Old Jun 6, 2015 | 07:05 PM
crazycage's Avatar
crazycage
Yea the rest is easy mate just need good clean gear changes and not ride into the limiter
Old Jun 7, 2015 | 10:18 AM
gjh's Avatar
gjh
Bloody good going! Will it see 10s in its current setup? Or will you have to make changes?
Old Jun 7, 2015 | 11:12 AM
Rsmat's Avatar
Rsmat
Wow what a engine ..Top respect ..what sort of parts and price to build something like that ..via PM ..I'm wanting a low lag 250-260 zetec with a borgwarner built ..so just looking at ideas and what I'd need ..thanks Mat
Old Jun 7, 2015 | 12:09 PM
crazycage's Avatar
crazycage
Making some changes to the cooling system and fitting a cage and taking a bit more weight out of it .will have more power when i fit the new twin plate clutch .i should be getting terminals between 130-135mph
Old Jun 7, 2015 | 12:29 PM
crazycage's Avatar
crazycage
No I was only there for the day mate
Old Jun 7, 2015 | 12:33 PM
crazycage's Avatar
crazycage
250hp is easy mate ,I wouldn't bother with a borgwarner at that power tho there's plenty turbos that will make that power and spool early . I'd be looking at standard Subaru or Evo turbos cheap as chips would need a manifold to suit tho
Old Jun 7, 2015 | 12:46 PM
Rsmat's Avatar
Rsmat
Thanks for that mate ..This zetec world is all new to me .. Cvh and YB I'm ok with ..just need to know how and what to use to build a nice zetec ..only for road use so 260 should be enough id have thought .
Old Jun 9, 2015 | 09:09 PM
allaboutfords's Avatar
allaboutfords
Just starting the same build myself for a mk 2 but had doubts put in my head about using C20let pistons and RS turbo LSD box anyone any thoughts.
Where abouts in Merseyside are you as im in Skem and will need an exhaust doing.
Old Jun 10, 2015 | 12:26 PM
crazycage's Avatar
crazycage
Originally Posted by allaboutfords
Just starting the same build myself for a mk 2 but had doubts put in my head about using C20let pistons and RS turbo LSD box any any thoughts.
Rs turbo gearboxes are a lottery even on standard power ,I wouldn't bother with c20let pistons either there's plenty of cheap rod piston packages these days .im over the water in wallasey
