3dr abs relays and fuses
Old Jun 1, 2015 | 04:46 PM
siscossie's Avatar
siscossie
3-door moonstone
Default 3dr abs relays and fuses
Can anyone tell me where the abs relays and fuses are in a 3dr please
Just repaired a wire that's rubbed through on coil bracket, but light still on must have shorted
Old Jun 2, 2015 | 06:00 AM
siscossie's Avatar
siscossie
3-door moonstone
anybody its driving me nuts
Old Jun 2, 2015 | 07:24 AM
JPA's Avatar
JPA
I'm sure they are above the ABS ECU which is located in drivers foot well behind kick panel
John
Old Jun 2, 2015 | 04:44 PM
siscossie's Avatar
siscossie
3-door moonstone
There is a bank of relays unsure which they are changed the fuses in yellow and green one , someone said there should be a purple one but can't find one
Old Jun 2, 2015 | 07:03 PM
JPA's Avatar
JPA
I have a look in mines the now and get a picture of what there
Old Jun 2, 2015 | 07:35 PM
siscossie's Avatar
siscossie
3-door moonstone
Cheers bud that would be a big help
Old Jun 2, 2015 | 07:37 PM
siscossie's Avatar
siscossie
3-door moonstone
These are the ones in the drivers footwell changed fuses in first two on the left
Old Jun 2, 2015 | 07:41 PM
siscossie's Avatar
siscossie
3-door moonstone
This is the wire on the plug that rubbed through new piece soldered in but still the light is on
Old Jun 2, 2015 | 09:00 PM
JPA's Avatar
JPA
Mines is the same as yours , funnily enough lol
Do you have a relay in the yellow plug as cant see in the picture ?
And does your pump power up with ignition ?
Have you tried driving car also to see if it goes out ?
When and how did fault occur ?
Old Jun 2, 2015 | 09:20 PM
siscossie's Avatar
siscossie
3-door moonstone
Light came on half way back from Santa pod did 100 miles with it on
Pump powers up when ignition is switched on and stays on when started
The light went out after I had repaired wire for about 5 seconds then came on again
Old Jun 2, 2015 | 09:21 PM
siscossie's Avatar
siscossie
3-door moonstone
Will check last yellow when I get home from work
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
