Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
focus sub
Old May 26, 2015 | 08:40 PM
stewart.d.campbell's Avatar
stewart.d.campbell
Default focus sub
Hi, the sub in my focus blew and i got another secondhand,(kenwood t10 0878 08)The original sub had just 1 voice coil but the kenwood has 2, i have just wired to one set of connectors but now it seems to be trying to play higher frequencys as well as the low so do i need to wire it differently ie http://a248.e.akamai.net/pix.crutchfield.com/ca/le... or http://a248.e.akamai.net/pix.crutchfield.com/ca/le...
problem is i dont know anything about the sub or the amp, the amp is the original option one and i cant find info on the sub, help.
Old May 27, 2015 | 07:12 AM
STeve's Avatar
Super Moderator
My focus has the built in sub which tbh is not the best but I would think its matched with the specific audiophile head unit which has the built in crossovers etc to send the right frequencys anything non oe unless of the exact same range will sound odd
Old Jul 9, 2015 | 06:22 PM
stewart.d.campbell
Ok was planning going down a different route with this now as i have an old kenwood amp with lp filter so how do i wire it, what goes where.I have 2 red wires 2 black wires 1 red and white 1 black and grey and 1 white and black, the amp is rca input, thanks.
Old Jul 9, 2015 | 08:40 PM
stewart.d.campbell
Why is there 2 powers and 2 grounds and how do i split the sub + and - into the rca,s to the amp.
Old Jul 10, 2015 | 10:25 AM
STeve's Avatar
Super Moderator
if re using the OE sub box simply use the correct wiring for the amp and speaker being used and ignore fords totally as its very low rated
Old Apr 3, 2017 | 08:22 PM
Vindi93's Avatar
Vindi93
If it has 2 voice coils and your original was 1 then you have to link the 2 voice coils together as you maybe using the wrong impedance. You need the positive on the one coil linking to the negative on the other coil.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
