Saff seat bolts/ fixings
Im after the bolts that you fix the front seats to the floor pan. Anyone found a cheaper supplier than the thieving gets at ford?
Do you need original bolts?
The standard ones are M8 lock bolts (if you wrap your fingers around one, then instead of the thread section being completely round, it feels slightly triangular).
If you don't need original, you could replace them with normal high tensile M8 bolts.
If you have a mint set of 8 then let me know.
Russ Payne
Sep 25, 2015 08:29 PM
