Saph cos 4x4 idle screw
Old May 26, 2015 | 12:36 PM
gcfcos's Avatar
gcfcos
Default Saph cos 4x4 idle screw
Hi chaps been meaning to set my idle up for a while since the stage 3 msd chip I fitted then caused it to hunt on idle. Was told when car warm to unplug idle control valve and set idle to 850rpm and then plug it back in. Turns out the idle screw is seized. Removed throttle body and soaked overnight with wd40 down the hole but was still full up come the morning and still no movement. Looks like I may poss need a new throttle body :-( anyone had this problem before?
Old May 26, 2015 | 02:05 PM
James @ M Developments.'s Avatar
yes,they can be a real pain to move if they have been stood a while without being touched.
Old May 27, 2015 | 04:59 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Had the same with my old throttle body. I think if you drill it out you can get new screws of fleebay iirc. I have fitted another throttle body with a different type of idle screw that has a nut around the screw. Guess its a 2wd one?
The screw is brass I think on the 4x4's?
Old May 27, 2015 | 07:46 AM
gcfcos's Avatar
gcfcos
Ah cool I didn't realise u could fit the 2wd one
Old May 27, 2015 | 08:28 PM
costina's Avatar
costina
Live long and prosper!!
Gently warm it up should do the trick.
If not find someone with a ultrasonic bath they work wonders with shitty old carbs.
Old May 28, 2015 | 02:22 PM
gcfcos's Avatar
gcfcos
I've decided after the car show I'm going to next weekend I'm gonna pull the throttle body off again and plan to either use my impact driver on the screw and failing that try heating it up gently. If not then I'll just get a second hand throttle body
Old May 29, 2015 | 07:27 PM
kosienutter
Yeah. I just put my 4x4 TPS on it and its all good.
BigD.
Alloy wheels and ICE for sale
Sep 16, 2015 03:08 PM
gcfcos
88
Sep 15, 2015 03:48 PM
RSmark84
Sep 13, 2015 01:29 PM
truffleshuffle
Sep 10, 2015 09:35 PM
hopper350
Sep 4, 2015 12:53 AM
