Where exactly is the engine number on a cosworth 200 block?
Old May 23, 2015 | 11:26 PM
M K's Avatar
M K
Default Where exactly is the engine number on a cosworth 200 block?
Where exactly is the engine number on a cosworth 4x4 engine block? and how many letters/numbers is it?
I can not go by chassis number as the engine is a second hand item
Also is there anyway to tell if it is a sapphire 4x4 200 block or an escort cosworth 200 block just by looking?
Thanks
Marc
Old May 24, 2015 | 03:10 PM
costina's Avatar
costina
Live long and prosper!!
Usually found above the water pump unless its a new block.
Old May 24, 2015 | 03:12 PM
costina's Avatar
costina
Only possibly the build number will give you an idea. Will sort a pic in a mo.
Old May 24, 2015 | 03:17 PM
costina's Avatar
costina
5 numbers hope that helps
Old May 24, 2015 | 07:01 PM
M K's Avatar
M K
Thanks mate, I have no number on my block in that location though
Old May 24, 2015 | 07:14 PM
costina's Avatar
costina
Probably a new block my other one has no numbers.
is there any on the exhaust side of block?
Paul
Old May 24, 2015 | 07:15 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
It should run along the bottom of the block same side as the 200 stamp
Old May 24, 2015 | 10:10 PM
costina's Avatar
costina
Above is also correct along with numbers sometimes stamped by the gearbox mounting lug. And on the lug would be engine code as per pinto ie N5A for example which was a 205 injection pinto.
Paul
Old May 25, 2015 | 10:18 AM
M K's Avatar
M K
These are all the numbers I can see at the moment, going to have a closer look later
2222
C8S1A
V90HM6015AB
Any ideas?
Thanks
Marc
Old May 25, 2015 | 11:51 AM
JPA's Avatar
JPA
2222
C8S1A
V90HM6015AB
Any ideas?
Thanks
Marc
The number starting v90 is most likely to be the actual part number for the block
The actual engine number should be stamped on the o/s of the engine on a flat area right of where it has the raised 200 letters
And slightly behind and above the alternator mounting , if this is clear of any markings then you most likely have a new block as said already
The four 2's are relative to piston sizing as there is four choices 1 to 4
ie an engine could have 4112 indicating the actual piston used in each bore
Ford ask for this info when ordering pistons
John
original
Apr 28, 2026 05:20 PM
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
RsS2daz
Aug 14, 2015 05:26 AM
Zoggon
Aug 10, 2015 10:39 AM
