Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Oil temp on a focus st170
Old May 22, 2015 | 08:30 PM
hughsie's Avatar
hughsie
Default Oil temp on a focus st170
My 04 focus st170 oil temp has just started going up and down while driving will stay constant at half way when ticking over but while driving goes up and down oil pressure is fine water temp is fine renewed thermostat and housing has anyone had this problem with the st170 and does it have an oil temp sensor if so where is it on the engine never goes above half way but is it affecting the way the car runs
Old Jul 7, 2016 | 11:20 PM
batrst's Avatar
batrst
there normaly on back of engine mate
Old Jul 8, 2016 | 05:42 AM
STeve's Avatar
Super Moderator
when was oil last changed as worn/cheap oil can cause this too
Old Jul 8, 2016 | 06:29 PM
RichieST's Avatar
RichieST
Fairly sure mine used to go up and down when driving, it's normal don't worry too much. As long as the water temp isn't rising past half way.
Old Jul 8, 2016 | 08:35 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
It will go up and down as when your driving the oil is being pumped around a engine that's also have coolant pumped around the head and block so should keep it a nice temp unless your ragging the shit out of it , sitting there is allowing the oil to get hot hence why cars have cooling fans to cool the coolant which intern cools the oil to a safe constant temperature
Mine does this all the time so I wouldnt worry about
Cheers Paul
Old Jul 11, 2016 | 03:30 PM
hughsie's Avatar
hughsie
thanks for your replies i do not have the car any more but i did find out what was wrong with the oil temp.the oil temp gauge is not connected to the oil system it is connected to the water temp so it is not an accurate measure of oil temp.The problem was a faulty thermostat once repaced the oil temp went back to normal
YODI
Aug 30, 2015 01:12 PM
Ford Focus ST Parts for Sale
Aug 28, 2015 01:32 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
