Cosworth just backfiring on ignition
Old May 16, 2015 | 03:55 PM
BRAMMER's Avatar
BRAMMER
Default Cosworth just backfiring on ignition
The car won't fire it keeps back firing - i did have this running about a month ago but recently just give up
new cps 0.8mm, phase 0.25mm, new plugs, leads & tried replacement coil and nothing - it has a spark and a good one but won't fire.
The only thing is the fuel was 18 months old and i topped it up with a gallon of fresh is it likely the fuel is bad or should i be looking in another area?
Timing appear fine as the engine was just rebuilt and everything lines up as it should?
Old May 16, 2015 | 04:03 PM
Mark Shead's Avatar
Mark Shead
First check plugs not wet if ok change leads around as sounds like firing order wrong.
Mark
Old May 16, 2015 | 04:07 PM
BRAMMER's Avatar
BRAMMER
Thats what i thought but why as the coil is numbered and the specific lead goes to cylinder as wasted spark
With all the timing marks lined up all appear to be in the correct position - the dizzy hasn't the arm and the notch in the shaft is facing the mark on the body around 1 / 2 O'clock - but the pickup on the shaft doesn't meet the phase. Should it when all others line up?
Old May 16, 2015 | 04:15 PM
Mark Shead's Avatar
Mark Shead
Don't worry about marks swap them over and try.
Mark
Old May 16, 2015 | 04:16 PM
Mark Shead's Avatar
Mark Shead
It's a quick 1 min check to see what it changes.
Mark
Old May 16, 2015 | 04:57 PM
BRAMMER's Avatar
BRAMMER
What formation mark swap 1&4 on the same bank or swap them with 2&3 ?
Old May 16, 2015 | 05:05 PM
Mark Shead's Avatar
Mark Shead
Swap 1 4 to 2 3.
Mark
Old May 16, 2015 | 05:14 PM
BRAMMER's Avatar
BRAMMER
Mark it fire fine and ticks over, if you throttle its a little spluttery - Mark i don't understand pal
Old May 16, 2015 | 05:15 PM
cozzy jeff's Avatar
cozzy jeff
mine done the same when I changed to wasted spark after swapping the leads around it fired up.
Old May 16, 2015 | 05:16 PM
cozzy jeff's Avatar
cozzy jeff
probably all the fuel you've pumped into it trying to start it?
Old May 16, 2015 | 05:28 PM
Mark Shead's Avatar
Mark Shead
Just check to make sure it's timed correctly and not 360 out.
Mark
Old May 16, 2015 | 06:34 PM
BRAMMER's Avatar
BRAMMER
Mark
Cheers Mark info massively appreciated, i'm absolutely confused still but the car runs like a swiss watch with a new set of plugs in it so i'm back on track
Old May 16, 2015 | 07:00 PM
Mark Shead's Avatar
Mark Shead
Its one of the most common problems and such a easy out to check,
I had a Mini race car come in doing the same and had been to several traders before and they couldnt find it,
I had it running inside of 5mins.
Mark
Old May 17, 2015 | 05:07 PM
BRAMMER's Avatar
BRAMMER
Mark
Crazy, will remember that one
Old May 31, 2015 | 07:20 PM
Adam-M's Avatar
Adam-M
Glad it's ok bud and well done mark!
Old May 31, 2015 | 07:34 PM
James @ M Developments.'s Avatar
If the coil is working backwards from its labels, either don't worry about it, or swap the blue and purple wires on the wasted spark driver where they solder onto the ecu pins.
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
hopper350
Sep 4, 2015 12:53 AM
