Sierra fuel/temp guage problems
Hi All, I am using a 1989 Cosworth Sapphire as donor for a kit car. Due to the car being written off I have been able to use all parts for project including instrument panel and wiring loom. Unfortunately I had trouble with the wiring and sent to many "experts" who made a complete mess of everything. Before being mutilated I had got the engine running and a correct(ish) reading on the temp gauge but not the fuel gauge as it was not connected. I have now managed to rectify most of the "experts" faults apart from the fuel and temp gauges which are now both reading maximum after a few seconds. The temp sender is now new Ford item and the fuel sender is via Westfield.
My Question: On the wiring diagrams they refer to a rectifier for these 2 gauges but when I take the panel apart there is only direct connections through the PCB, am I missing something, should there be another component? I do see there is a diode meant to be in-line on the Brown/white from the temp. sender which "experts" may have removed but would this affect gauges or have they possibly cooked them.
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
