Cosworth parts - updated list.
I have for sale lots of parts from a sapphire I have bought for some specific bits I need, vehicle has had extensive rear end damage, no front end damage.
Cosworth engine from a 4x4 sapphire (G reg) mileage tbc, was running pre-accident £2500 (205 block- 4x4 head etc)bare (no inlet/exhaust ono
T34 orientated for 2wd can still be for a 4wd proper 0.63 no cracks, like new £480 - looks to have been rebuild recently by AET has large forged actuator
Gearbox £220
Blue Samco hoses ALL (coolant) £60
2wd exhaust manifold
£80
Radiator and fans slight wear to the mounts, not noticed with the rubber mounts in (genuine Behr) £80
Steering Rack & PAS pump £100
2 x 17" alloy wheels 7 spoke I think, might be RS motorsport things with center caps x3) the have tyres but have not checked them for condition - tread is ok though but do not take this as they tyres are good £100
Koni front top adjustable dampers and springs found one to have the usual Koni bend - can it be fixed ? price adjusted £40
4wd antiroll bar £40
Powerflex (or some kind of poly bushes the chassis mounting ones (purple) for antiroll bar £15
Blue motorsport plug leads (like new) £60
4WD rear vented grooved and drilled rear discs £40
4WD vented grooved and drilled front discs £40
Front crossmember £40
Engine Harness has been removed from the main parts, still has the three bulkhead plugs in £100
Various switches, clock, ABS ecu, bulb warning and ecu,
4wd rear discs grooved and drilled
£40
All parts ONO collection only on large items, paypal if you are paying the fees (bloody rip off merchants or gift)
Ta
Gearbox £220
£80
£40
Ta
3dr cossie
11
Dec 21, 2015 03:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
