Welding Prices
I need to have a bit of welding done on the KA.
How much would you expect to pay to have the filler cap surround cut out and a new panel welded in with a supplied panel and both outer sills cut out and replaced with supplied panels?
Bailes.
Bailes.
It's open ended, unless seeing it it's difficult to say how far it's gone, also do you want it filling and painting etc, I would say anywhere from £400 plus and that would be very cheap
Ah... serves me right for trying to post while I'm walking around.
The sills are actually solid apart from one small patch about the side of a 5 pence on the passengers sill and the front end of the sill has started to go on both sides.
The filler cap has been repaired once before and isn't bad but it's beyond another repair.
I want to get the car solid so I can underseal it properly.
I'll supply new panels myself.
I'm looking to have it ground back but I'll be filling and painting myself.
