Cosworth ST block and head tuning?
Old May 4, 2015 | 10:23 AM
RS200dan's Avatar
RS200dan
Default Cosworth ST block and head tuning?
I have been offered a Cosworth ST block (inc pistons and crank) and head (only with inlet no turbo or manifold) for a fair price but wanted to know how easy it would be to tune as I heard bad things about tuning ST engines? Engine is going to be used in a kit car if that helps?
Dan
Old May 4, 2015 | 10:26 AM
Mark Shead's Avatar
Mark Shead
It's only the standard cars ecu that's the problem
Mark
Old May 4, 2015 | 10:27 AM
james kiely's Avatar
james kiely
you probably have the best cosworth block due to the oil squirt jets already installed as standard dan.
they will tune the same as any other cosworth engine ,as it was the later ford ecu that was the limiting factor on the st cars .go aftermarket ecu or the p8 / l8 ecu and the world is your oyster
Old May 4, 2015 | 12:00 PM
jsa's Avatar
jsa
Nothing wrong with the ST engine.
Just seems to be an aversion to tuning the eec-iv ecu.
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
