GTX3071R turbo with .82 turbine housing internal wastegate with seperate exhaust and wastegate exit.
This fits standard 2WD exhaust manifold when fitted with spacer.
Rated at 560BHP.
Alright Bart I think you have priced that a little high ??
I bought a brand new gtx30/71 1050 ? I'm just saying
Cheers Marco
Hi Marco, this is with a .82 turbine housing with internal wastegate, divided wastegate/exhaust flange, oil restrictor and actuator.
Yours is the same????
what power did this make and how much mialage is on the turbo?
This turbo was on a trackday car witch done around 15 hours so not very much miles.
Was running 435bhp @ 1.5 bar boost. We kept it low boost to save transmission. Was still the standard 4x4 gearbox but it broke anyhow.lol
Now uprating gearbox and engine going efr turbo.
Very nice turbo and not that laggy like they say imo.
Any power graphs?
When does this start to make positive boost.
Is it much different then the T4 turbo that require allot of revs to get going?
It is a lot different imo.
It makes 1.7 bar around 3500 rpm.
I dialed the cams in to get more response and less top end.
This is also very important to how the engine spools.
