Focus rear lower control arms
Old May 2, 2015 | 05:22 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Default Focus rear lower control arms
I was thinking of working on the handling side of my ST170, and wondered if anyone has fitted these..
http://dominantengineering.bigcartel...r-control-arms
Or knows of a more local company that makes them, many thanks
Old May 2, 2015 | 06:01 PM
jonfoc's Avatar
jonfoc
I know a couple of people that fitted them and have both taken them off. One bent his and the other didn't want to risk it.
Just fit decent dampers and springs combined with adjustable camber arms.
Old May 3, 2015 | 07:20 PM
MJ_RST's Avatar
MJ_RST
They look shocking. Whats wrong with the Hardrace ones?
Old May 5, 2015 | 07:27 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
the big lower ones are for toe and the standard adjustment is more than capable of doing what you need. yours will probably be seised though.
if you want camber adjustment the cheapest option is eibach camber bolts which will give you all the adjustment you need.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
skypeller
Sep 19, 2015 09:58 PM
155lee
Aug 14, 2015 11:21 AM
