Oil return under oil level cosworth 4x4?
Old Apr 29, 2015 | 11:58 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Oil return under oil level cosworth 4x4?
I am upgrading the standard breathing on my cosworth. Looking at the oil return pipe on my 4x4 cossie in the sump I am not sure if this really is under oil level. The return pipe is fitted at the upper side of the sump. That would suggest the sump must be filled up to its top to get this oil return under oil level.
Is there someone who can tell what the situation for this oil return is inside the sump?
Old Apr 29, 2015 | 03:11 PM
Albertodelgado's Avatar
Albertodelgado
hi Wim the pipe that goes into the sump at the top is going down to the bottom inside the sump below the oil level
Stephan
Old Apr 29, 2015 | 03:14 PM
Albertodelgado
Old May 2, 2015 | 08:52 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Super Stephan, thanks!
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Anutternutter
Aug 21, 2015 06:07 PM
mrmann
Aug 20, 2015 11:24 PM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
