Mfi to efi conversion ofab management and so on
Included is
Ofab engine loom
Ecu x2
Co pot
Edis
Map sensor.
All tested tonight. Co pot needs setting
I'm including another ECU that is damaged and doesn't work...don't need it so including it.
Efi inlet manifold
Injectors with fuel rail. This requires a bolt and maybe a new regulator. Basically. I couldn't get the cap off that's all. It's preset to 3 bar of fuel pressure so will run fine as it was used on my car.
Mfi to efi inlet plate.
Trigger wheel with sensor for crank position.
Coil pack. You will need some leads.
Basically, this is nearly everything you will need to run an mfi on efi management except for a few little bits.
Listed as spares repair as I sold the management on ebay and the buyer swapped the ecu for a damaged one and sent it back. I have since got a new ecu that is in working order.
Can post or collect from Morden Surrey
£400
07545395993 for info or pictures
Ofab engine loom
Ecu x2
Co pot
Edis
Map sensor.
Efi inlet manifold
£400
Sold...but I have..
Efi Rs turbo engine for sale! Head and block (needs rings). The bottom end had a new waterpump and oil pump at some time. Skimmed flywheel also included.
£150 collected from morden/surrey
mk3ste
Oct 17, 2021 10:09 AM
deathrider666
Sep 28, 2015 06:12 PM
