Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Focus St underboost
Old Apr 26, 2015 | 05:48 PM
Tuppy55's Avatar
Tuppy55
Default Focus St underboost
Hi guys.
Basically I had a dyno on my car and found out the car isn't boosting properly. So we replaced the solonoid. And messed with the actuator. Got it working perfect it made 311bhp.
Then after the dyno I realised the car wasn't hitting full boost its sitting at half.
I was told it could of blown the recirc valve with the pressure a common fault so I went and brought a forge uprated recirc valve fitted it and it's still only
Hitting half boost.
Could it be down to the actuator? If so how would I set it up?
Or could it be something else.
It does though an error code up saying turbo under boost??
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
