wideband lambda info reqd
Old Apr 26, 2015 | 04:53 PM
slider's Avatar
slider
Default wideband lambda info reqd
A L8 cossie ecu has a standard lambda sensor fitted, if i fit a wideband is it just a case of ditching the lambda or can i connect the wideband controller to the ecu?
its a techedge j2 setup ive got
Old Apr 28, 2015 | 10:48 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
If your wideband controller has a narrow band emulator output then you can feed this to the ECU. If not, a wideband won't give the correct signal to the ECU so it will need to keep its own narrow band sensor. The two types of sensor work in completely different ways so are not cross compatible.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Mc5506
Sep 29, 2015 09:06 AM
