Escos cooling
Old Apr 25, 2015 | 05:27 PM
mk2 escort boy's Avatar
mk2 escort boy
Exclamation Escos cooling
As title I'm having a few issues I'm about to smash the thing
The car was running fine no probs what so ever then I noticed it was getting a little warm not in the red but close I thought fan switch had packed up so ordered a new fan switch and thermostat fitted it no change still getting hot ffs
I check the connections all good fuse is fine still nothing
Now this could be nothing but I was running out of ideas so I looked at the ecu well I mean I un clipped it from its place and the fans come on i thought great went and got a cuppa the fans were cutting in and out result not sure what done it but hey
I put the ecu back and the fans cut out now they won't come on ?
Any ideas
Old Apr 25, 2015 | 09:36 PM
cossiestu's Avatar
cossiestu
I know you can get a replacement loom for the fan, but not sure exactly what specific faults it cures?
Old Apr 26, 2015 | 07:12 AM
fraser9764's Avatar
fraser9764
Not sure where the standard wiring runs. But as Stu says MSD do a rewire loom which just plugs in to to the fan switch and battery so all original wiring is removed.
one for sale here if you're interested.
https://passionford.com/forum/ford-r...r-map-etc.html
Old Apr 26, 2015 | 10:18 AM
St3V3_C's Avatar
St3V3_C
It's been a while since I've looked at any of this, but I'm 99% sure the fans don't have any connection to the ECU on the big turbo - what's yours? I know nothing about ST
Old Apr 26, 2015 | 10:21 AM
mk2 escort boy
Big turbo mate
Old Apr 26, 2015 | 11:20 AM
St3V3_C's Avatar
St3V3_C
OK, so just that double switch it the rad then. First (lower) temp the fans are run in series (6V each) then if it still gets hotter they both get 12V.
Old Apr 26, 2015 | 11:50 AM
mk2 escort boy
Sorry ? The fans aren't coming on
Old Apr 28, 2015 | 04:42 PM
R4N SS's Avatar
R4N SS
just buy a rewire kit - peice of mind and all that mate.
Can be had from MSD and several other tuners also and egay
gcfcos
59
Oct 6, 2015 05:04 PM
Chas
Oct 5, 2015 07:13 PM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
