Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk3 fiesta water in fuel
Old Apr 23, 2015 | 06:13 PM
CharlieRSTurbo's Avatar
CharlieRSTurbo
Default Mk3 fiesta water in fuel
hi, I've got a mk3 fiesta but water keeps getting into the fuel system,
Checked fuel cap and it has a great seal, anyone else had this problem?
Old Apr 23, 2015 | 08:50 PM
3i Jim's Avatar
3i Jim
10 Year Member
Petrol or diesel?
Old Apr 23, 2015 | 10:07 PM
CharlieRSTurbo
Petrol mate
Old Apr 23, 2015 | 10:36 PM
CharlieRSTurbo
I'll give you some more information its a 1.1 carb engine and i've bought it for this reason thinking it might be easy fix because I want to rs turbo it, but before I start the conversion I want it running right first, also the guy I bought it off is a gardener so I'm wondering if he's filling it with Jerry cans of fuel since he probably get fuel cheap off someone which will be crap fuel anyways, I might start with a full fresh tank of fuel from asda petrol station and run a fuel additive system through it, see if that's clears anything.
Old Apr 24, 2015 | 07:55 PM
3i Jim's Avatar
3i Jim
10 Year Member
Drain the tank completely and put fresh fuel in and go from there.
Old Jun 5, 2015 | 07:04 PM
CharlieRSTurbo
So for late reply, fully drained fuel out and it's started again with the water in fuel system, in tempted to drill a small hole in the tank and leave it to drain out, which I've heard people used to do back in the day, someone mentioned checking the charcoal canister? But not sure where it is.
Thanks
andyrs1600i
Apr 29, 2026 03:21 PM
Ben26
Aug 27, 2015 08:56 PM
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
Bosch
Aug 4, 2015 05:14 PM
