Bore sizing and reliability
Quick question on 200 block.
Because of needing another rebuild I need to go to 91.75mm on the bores.
What is the consensus on running circa 2 bar and just under 500bhp that oversized??
Trying to work out if I should go liners or not.
I'm long enough in the tooth to know who best to listen to!
I was actually talking to Piero and he said to speak to you about what you offer but you only do complete builds don't you?
He priced up a nikasil lined block for me and 10 long studs.
Does anyone go dry liners?
Mark
If it was me id dry liner it to std size.
Westwood liners are good.
but by the time you spend on a 200 block sleeving boring studding would it be better to purchase a alloy block.
Also you will save weight.
Paul
Paul
I've spoken to Martin at Reyland Bout dry lining the block (Westwood) and was surprised how cheaply his can be done, block is already long studded. Alloy block nearly 10 times more expensive!!
Mark
liner is spun cast and stepped and glued in place. I believe where it will be done is where NMS and Reyland engines are dry lined.
Mind not yet made up on that though as I'm currently travelling with work in Asia and need to speak to my engine builder. (Grace engine developments)
Slight change of tack!
Selling my block and crank now and have bought newly nikasil lined, oil squirt jetted block with an Arrows crank and Carrillo long rods (ex Julian Godfrey rallyx) also 9.5:1 JE Pistons but may not use these as bloody high cr and I'm not running a 48mm restrictor and race fuel.
Yea, bout 4.5k then a decent, crank, rods, Pistons then I'd want an alloy head as well so everything expands at the same rate.
I'd put true end built cost at closer to Ł15-20k depending on spec. That's without inlet, exh manifold, turbo etc
Ouch! I love the idea of lopping 25kg off the front axle weight but that is a big outlay. I really would like to long stroke mine but,again, it is really expensive
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
