Cossie parts. silicone SFS Hoses, sensors, mounts ,etc. More added 19.5.15
Got these parts still laying around since i broke the saph. These parts are being stored inside the shell and i need them out as the shell is being collected soon
Will have a few engine parts and a couple of gauges up soon too.
All parts + post, or collection from West Sussex
Set of SFS silicone hoses. RS500 size, 5 ply Boost hoses, 2wd Coolant/ancillary. The two heater matrix hoses not included ( as they have been cut. Although your welcome to them ). Pictures if needed as i havent taken any yet. £150
Pump to filter braided line with aeroquip style fittings £12
Top mount rubbers £5
Alternator mount £7
Front Aux oil seal carrier. £7
Kidney box £7
CTS £5
Wiper motor and linkage £10
Magnetti Marelli CPS and mount £15
Chrome top mounts. Bit grotty. £5
Tank strap. £5
Braided turbo oil feed £5
Proper, between the struts, strut brace. No bolts £50 SOLD
Ive got two prop donuts. Im pretty sure one is the thin type, the other the thicker. £20 each Both sold
Couple of Cometic gaskets. £5 SOLD
Hydrualic clutch conversion. Brought this a while ago, new , from a member on here. It was on the car for about 300 miles before it was removed. £50 SOLD
Gen Ford rear mudflaps for a saph cossie. All mounts there. £15 SOLD
Front bumper mounts £10 SOLD
Intercooler/rad rubber mounts. £3 SOLD
Alternator drop bracket £10. SOLD
Dump Valve bung. £5 SOLD
2wd Water temp sensor bracket. £5 SOLD
Morette twin headlights. Inner lenses have been removed and the outters are shit. New pair of cyrstal lenses are included. Usual condiditon with inside edge being cut to fit past the grill. Downside is one of the outer mounts has snapped off as pictured. Easy fix. £70. SOLD
Rear ABS sensor £20 SOLD
ISCV modded by MSD for ALS. Has been sitting around for a while and was run unplugged in my engine. So sold as untested. £20 SOLD
Std/Std crank. Polished 6000 miles ago. £425 ( i can get this polished and rechecked for an extra £75 ). SOLD
RS500 intercooler. Has taken a knock to the bottom which has twisted it . It was like this when i bought the car. Still works perfectly fine and put up with me pushing 36psi fromt a T4 through it. £150 SOLD
Rods SOLD
4x4 Big wing sump. This came fitted to my SCS engine. Has a Small threaded boss for a temp sensor and a large dash fitting for a breather return. The larger boss has been cross threaded at some point in its life, but my breather return still bolted up tight and didnt leak. Offers. SOLD
Ignition amp bracket £5 SOLD
4x4 Gearbox exhaust hanger and rubber £10 SOLD
Twin 52mm Pillar pod. Small crack at bottom, alarm sensor mount and hole for the wire in the top. £15. SOLD
Bailey Breather and hoses. Hoses have dash fittings to screw onto fitting on the above sump and onto the block ( block fitting not included as ive lost it ). £40 SOLD
4x4 Gearbox Cradle £10 SOLD
Pump and filter bracket. £15 SOLD
Front leather recaros. Usual wear on drivers bolster. £50 SOLD
205 Block, Honed 6000 miles ago. £150 SOLD
Alternator mount £7
Kidney box £7
CTS £5
Tank strap. £5
Rods SOLD
Pm'd
They are indeed a pair. Were removed from one bumper.
Pm'd
Pm'd
Thanks Glenn, Just want stuff out the way so the shell can go to my mate as im currently using it as a shed lol
Pm'd
Pm'd
Pm'd
I'll take the Bailey Breather and hoses. Hoses have dash fittings to screw onto fitting on the above sump and onto the block ( block fitting comes with too ). £40 if its still available please
I'm just waiting on tessatony to reply to a pm. If they don't have it, I shall drop you a message.
Thanks for the help! I ended up buying a new one and when it turned up its almost identical to this!
Should've just bought his one and saved myself over £100 quid!
Ran, someone messaged me a couple of hours prior to you. If they don't have it, it's yours. I'm just waiting for them.to empty their inbox as I can't reply to them
Bugger. I wanted the mudflaps too so if they become available then let me know mate
