Clutch
Apr 20, 2015 | 10:38 AM
Clutch
we have gone to change my clutch this morning because it was slipping under boost and the clutch plate looks fairly new!is there anything that could be causing the slip?
Apr 20, 2015 | 10:50 AM
clutch
too much power for the clutch-or a weeping seal/contamination??
Apr 20, 2015 | 02:30 PM
The clutch was dry as a bone and no signs of any leaks.
Apr 20, 2015 | 03:29 PM
What sort of clutch is it and what spec is the engine?
Apr 21, 2015 | 06:14 AM
The engine is a 2.0 zvh and the clutch we took out is stamped valeo?sorry I can't be more specific but I'm no mechanic!
Apr 21, 2015 | 08:51 AM
Valeo is just a standard clutch as far as I'm aware. Unless they do a uprated version.
Apr 21, 2015 | 08:58 AM
As above, sounds like a boggo standard clutch. And ZVH's tending to produce a fair chunk of torque will overcome this. Time to uprate
Apr 21, 2015 | 12:07 PM
That's what I figured,any suggestions?
Apr 26, 2015 | 08:54 AM
4paddle helix or ap using a custom pressure plate made to fit your flywheel and bearing.
need to order it through a deceny company tho for discounts etc.
Apr 26, 2015 | 07:15 PM
Quote:
Originally Posted by
Versus_Creations
What Jano said although I believe some here are used a stock cover and bearing
I have a Helix 4 paddle with the Helix cover. Jesus it is horrible to use. I understand that the above setup is far more forgiving.
Apr 26, 2015 | 09:46 PM
I've got a 6 paddle and standard cover and its spot on, nice and light, not snatchy, little judder but I don't think vibratechnics gearbox mounts help.
Reason: spelling
Apr 27, 2015 | 11:42 AM
So it's a toss up between 4 paddle and six paddle then?ive had a paddle clutch before and didn't like it much!!!!
Apr 27, 2015 | 07:24 PM
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
