330d/335d m sport touring
Old Apr 17, 2015 | 06:12 PM
grant_xr's Avatar
grant_xr
Default 330d/335d m sport touring
Another thread on BMW's
Think a few people on here have had/have these, I'm currently looking for one and they all seem to be around the 10K mark for 07 - 08's with around 100k on them.
Is that about right? There's a few rougher looking examples knocking about but I want on as clean as I can get tbh!
Would like an 09 facelift if I could get one at the right price!
Grant
Old Apr 17, 2015 | 07:01 PM
tony66's Avatar
tony66
Default 335
i have a 335d e92-its a 57 plate
seems to be a good fast economical car
havent had it long enough to get remapped or anything yet
i also have a 530d estate-e61 remapped deflapped dpf removed-i like that a lot to drive[doggie transport]
the 6 cylinder diesels all suffer from the same failings-main thermostats.egr thermostats,glow plugs, glowplug control units,flap failure/oil leaks at flaps
the 3 series suffer from light modules and above
if fitted with i drive this can fail
my 3 series has 19" wheels non rft and is a little harsh in the ride
my e61 is an early car with 18" rft and is a little jiggily over uneven roads but this is better on later cars-both mine have bmw m sport suspension package
Old Apr 18, 2015 | 07:48 AM
grant_xr's Avatar
grant_xr
Thanks for the useful info mate!
Does the prices sound fair for the age of car I'm looking at?
Grant
Old Apr 18, 2015 | 05:29 PM
grant_xr's Avatar
grant_xr
Went and drove one today...... Awesome to drive!
Condition was not up to scratch so back to checking Auto Trader etc!
Grant
Old Apr 18, 2015 | 06:04 PM
tony66's Avatar
tony66
Default price
10k about right as a starting point
insist on a scan with solus etc-as the heater relay and glowplugs dont fire up a warning light-also use the solus to check it gets up to correct operating temp[well above 70 deg] if it doesnt its likely to need both thermostats done[main one is nippy and an hour and a half work[ish] egr stat-five minutes
there is also a hidden menu on the dash for engine temp[no gauge fitted]
important that a standard car has all glowplugs working and gets up to temp as a faulty glowplug stops the dpf regen and it soots up dpf quick as it runs rich if stats are poor
yes-great cars to drive,335d 6 seconds to 60 standard and nippy top end-bags of grunt,and thats before a remap .....lol
Old Apr 18, 2015 | 07:32 PM
grant_xr's Avatar
grant_xr
Ok man thanks again
Any info on how to access the hidden menu?
Grant
Old Apr 18, 2015 | 07:59 PM
tony66's Avatar
tony66
Default hidden
Originally Posted by grant_xr
Ok man thanks again
Grant
you can get instructions on youtube etc on the menu -you wont get the fault codes for the heater plugs /heater plug relay etc though-needs scanned with decent kit
most of them need heater relays and heater plugs tbh-you have to remove inlet for the heater plugs and if doing one its as well doing all six-the relay can be done without inlet removal but its extremely tight-much easier with inlet removed
Old Apr 19, 2015 | 08:54 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Only experience of the 330d, watch for warping discs done cheap.
Thermostats as stated, i had to put mine in sport down motorway to get temp up as power was down significantly. Stats weren't expensive (gates are genuine bmw ones), over an hour to do.
Wiper motors get gummed up with grease, half hour job, may need a replacement relay too.
front tca's and tie bars on rear wear, again not that expensive or time consuming.
That's the bad so far, tyre wear could be a problem....
Remapped and it does like to shake is arse lol!
Get as many toys as possible, xenon lights are a must, i drive and sat nav too.
Got to be an m sport too, so much nicer looking.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
roomey
Sep 19, 2015 08:40 AM
