Saph air con?
Apr 15, 2015 | 09:58 PM
Saph air con?
Anybody fitted air con to theirs? Can it be done? Was unbearable today, cant be having that all summer!
Apr 15, 2015 | 10:36 PM
Quote:
Originally Posted by
STU20004X4
Was an option on sapph from factory although expensive so the odd installation could surface, 3drs also had the same option but very rare, aftermarket aircon systems available but don't know how it would fit these days with big intercoolers etc
Apr 15, 2015 | 10:54 PM
STU20004X4
I shouldn't worry, it'll probably not last long!?
Apr 16, 2015 | 05:59 AM
cossiestu
the car or the weather after all it is a saph
Apr 16, 2015 | 06:14 AM
Did Martin hadland not fit it to his black rs 500
Apr 16, 2015 | 06:52 AM
Yeh Martoon fitted ac to his 3DR.
My saff used to have air con. IT was an aftermarket kit though. I took the lot off cause it didn't work.
Apr 16, 2015 | 07:19 AM
Mine had factory aircon which I've removed but kept everything safe. It gets in the way a bit for big intercoolers as said but I'm sure I saw a kit to fit a bigger cooler with the a/c still fitted somewhere.
Apr 16, 2015 | 09:50 AM
The first two saphs I was gonna look at had air con, they were both k Reg. sometimes in the summer at shows I wish I had bought one of them!!
Apr 16, 2015 | 11:19 AM
Windows doon taps aff.
Translated put your windows down and take off your t shirt Bo-ya.
Apr 16, 2015 | 11:26 AM
I installed an original aircon set in my 24v sapph, it's in the project thread in my sig. But as already said by others, the condenser will be in the same location as an RS500 style intercooler on a YB. Although I do believe there are solutions for that, probably something like Martin used.
Apr 16, 2015 | 11:54 AM
Iv just palled the air con out of mine as it don't fut in my new shell
I had had the pump removed anyway so was a waste of space
Apr 16, 2015 | 12:39 PM
Also adds a fair bit of weight and rarely gets used i removed mine plus never find it to hot in mine!
Apr 16, 2015 | 02:17 PM
stevos
Translated put your windows down and take of your t shirt Bo-ya.
Yeh, thanks for clearing that up!? Didn't have a clue, I'm a southerner!
Apr 16, 2015 | 08:45 PM
STU20004X4
The bulkhead is different on the aircon cars I believe.
Ben Cresswell fitted it to his but it was quite involved as I recall after speaking to him
Apr 16, 2015 | 09:12 PM
Mine had air con fitted as standard.
Still icy cold too.
Nice when we get a summer
Apr 16, 2015 | 09:28 PM
jason_nike
Still icy cold too.
Lol, still icy cold, as it's only used for two days a year!
Apr 16, 2015 | 10:39 PM
cossiestu
That many, blimey I'm using it too much lol
Apr 17, 2015 | 09:33 PM
Mike1
That's right, I've done it to mine too.
Apr 18, 2015 | 05:54 AM
Mike1
You'll probably end up trying to find an entire air con model sierra just to cut out the bulkhead section.
it would probably be easier to fit some kind of aftermarket kit I'd have thought?
Apr 19, 2015 | 12:20 PM
[QUOTE=Mike1;6581451]The bulkhead is different on the aircon cars I believe.
Yes bulkhead is different so would need modding to fit OE stuff
Apr 19, 2015 | 12:25 PM
Plus if you want OE stuff on a non facelift sapphire, you need to move the PS pump to the exhaust side as the OE aircon pump mounts in it's place.
Apr 20, 2015 | 06:31 PM
I did it years ago in my saph cosworth.I pulled it out of a ghia.
Its a dashboard out job,and you have to cut a big hole out of the bulkhead.
Also had to change to a polly-v setup,so i could get the ac pump in,oh and had to make a mounting bracket for the pump.Other than that all went in pretty easily.
Still have a a few kg of r12 in the garage if you need any.
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
