N/A silvertop zetec tuning
Mate of mine ran following on his 2.0 silvertop:
Jenvey throttle bodies
Piper cams
Head work
4 branch and full Magnex
It made 191bhp on the r/r but tuner suggested fuelling was slightly out, and a bit of tweaking would see 200...
Piper cams
Head work
It takes quite a bit of work to get 200+bhp out of a zetec, you'll need better pistons and conrods, bolts etc, high lift cams (possibly more than a fast road profile) quite a bit of headwork, maybe using bigger valves, throttle bodies, an ecu to run it all and a good tubular manifold.
For a pokey fast road spec Zetec, I'd go Gixxer 1000 bodies, cams, a good 4-2-1 manifold and leave it at that, they get expensive to tune much past that.
As above, a 2.0 Duratec is much easier to make 200 out of.
Bike carbs ( mine are mikunis) megajolt ecu and an exhaust, no need to spend big money on a zetec for decent usable power, if it has to be 200 bhp though I'd definitely go for the duratec
This guy managed 220bhp out of a ST170 and still on the standard inlet manifold
https://www.facebook.com/ceri.jones....53781615009848
Lots of other modifications to get there.
Impressive! Was it the standard injectors too?
Don't think so. think in was on a MBE ECU.
The head was done my Andrew@ALD and I've seen a standard one next to his head work and loads have been done to the head..
Loads more info on the link I posted
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
