Tdci focus 2005
Hi guys, been a while since I wrote. Post!
Basically I put my focus throu mot fri and it passed but the mechanic said, sounds like your engine is gona go bang!
Personally I always thou it has been fine , it does make. Noise like a bit of plastic juttering when I toe it in first towards end of gear but other than that it's spot on , it has done 113000 miles 1.6 tdci,
Could the mechanic be right?
Ah I see, I had few probs with it at the start, I've been told it needs a new thrust bearing, when clutch is no pressed it makes a rattle noise every so often until I press down on clutch! Could this be why he thinks it sounds rough? I'm considering getting a new bottom end for it , 50/50 tho
The Enigma
Sep 29, 2015 10:31 AM
