Help with ECU
Old Mar 27, 2015 | 04:01 AM
ossie cossie's Avatar
ossie cossie
Default Help with ECU
I recently bought a cosworth engine from the UK, it came with this ECU> i know its an L8 but can anybody help with other info on it, what BHP is it capable of with the 3 bar MAP and 403,s what type are those injectors? Does anyone recognize the ECU or the name on it.
Thanks.
Tony.
Old Mar 27, 2015 | 07:28 AM
William MK2 Cosworth's Avatar
403's are the bosch grey injectors, but you will only find out what bhp it is capable of, if you know the rest of the set up it was intended for, i.e. cams compression ratio, turbo and so on.
some of these could be figured out if the ecu was calibrated for the engine you got, but there is no way of knowing if it was
The best solution would be to find out what is fitted to the engine, and then get a new chip from any tuner for that spec, or at the least yuo could find out what bhp the whole set up would make, not just the ecu
Old Mar 27, 2015 | 07:57 AM
Mark Shead's Avatar
Mark Shead
It is a Ahmed Bayjoo stage 1 chip for 4wd and ecu is a lambda version.
Mark
Old Mar 27, 2015 | 10:20 AM
Stu @ M Developments's Avatar
PassionFords Creator
Mark
I agree with Mark. That chip isnt for greys at all.
Old Mar 27, 2015 | 02:29 PM
ossie cossie
How could you tell that is is written on the chip? what injectors would it need ?
Mark i have been in touch with Scott at EMTRON here is OZ looking at getting an ECU from them in the future, may just get the motor running on this one 1st then swap over later.
Old Mar 27, 2015 | 02:42 PM
Ahmeds Standard labelling.
2B = 2 bar
L8 = L8
FR = Fast Road
Blu = Blue Standard Injectors
AB in circle = Ahmed Bayjoo
8/96 = August 1996
Old Mar 28, 2015 | 01:13 AM
ossie cossie
Awesome mate. If i ever sell it that info is great for the next purchaser.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
