New focus 1.8 cam belt not running true
Old Mar 18, 2015 | 02:13 PM
roger69's Avatar
roger69
Default New focus 1.8 cam belt not running true
I have just replaced the cam belt and it is not running true it is hanging over tensionern by about 2/3mm and the bearing sounds as if it is about tosieze up.l used a new dayco kit and it was buzzing after I installed it so took it out and reinstalled it again and it quietened down but is know running off centre towards the front by about 2/3mm and is noisy what's happened and is it safe to use
Old Mar 18, 2015 | 02:56 PM
london_chris's Avatar
london_chris
id buy a 2nd new kit, fit 2nd kit, get car on road and get the first kit refunded if possible
deffo wouldnt use it if it sounds like its going to to seize and the belts off the tensioner.
Old Mar 18, 2015 | 07:44 PM
studabear's Avatar
studabear
Have you got the tensioner fitted correctly?
Old Mar 19, 2015 | 10:14 AM
roger69's Avatar
roger69
I have done 4 other cam belts before a Mondeo diesel 2 escorts and a scenic without any trouble infact the escorts use the same tensioner and they were fine.I am using it at the moment as I need it to get to work, its just the tensioners a bit noisey
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
cos elle
Sep 1, 2015 06:48 PM
robnock
Aug 22, 2015 10:51 AM
taylora1409
Aug 12, 2015 12:06 PM
